Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 01, 2004 > Optical Wire for Xbox Surround Sound
Author Thread: Optical Wire for Xbox Surround Sound
Username: Nasmatic23
Ok, I recently bought the Xbox High Def. Pack to play on my plasma and have surround sound with my Bose Lifestyles system.
I have the video working great, but I can't seem to get any sound. I have an optical wire hooked up to the Xbox to the Bose system.
Is there a certain input the Bose System should be on to use optical audio?
Any help would be greatly appreciated. Thanks.
Man, this place really sucks.
Anyone? I could really use some help here....
Username: Project6
Post Number: 156
is there a digital input button on the Bose Lifetyle system? and is it configured to accept digital input signals?
have you configured the xbox?
there's just not a lot of people here that own the Lifestyle system. Probably why you're not getting a lot of responses.
Username: James_s
on some receivers you have to select analog,digital or optical input for your different audio selections. ie, dvd, cd,md, video 1, etc. be sure that your setting for whatever you have your X-box set to is set for an optical input.
zack
GO to your XBOX dashboard inside the sound or audio options and select Dolby Surrround or 5.1 option. That would be my first place to check. If this option is not selected the XBox will only send stereo sound.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 01, 2004 > Optical Wire for Xbox Surround Sound [ « Previous ] [ Next » ]
