Thread: Green tint with samsung 5.1 |
New member Username: Rebelwork
Post Number: 5 Registered: 12-2003
| Posted on Saturday, January 24, 2004 - 07:06 pm: |
i hooked up a 300 disk sony dvd player,vcr and an XBOX to the samsung dvd 5.1. everything works correctly except when i use the samsung to play dvd's. i get a green tint that i can not correct. is there a reason im getting this green tint from the samsung and not the other units? a connection maybe?....jack |
New member Username: Project6
Post Number: 133 Registered: 12-2003
| Posted on Sunday, January 25, 2004 - 11:12 am: |
are you using component video cables? try checking those, one maybe plugged in wrong, lose or jut bad cheers |
Post Number: 6 Registered: 12-2003
| Posted on Sunday, January 25, 2004 - 02:14 pm: |
yes component. never hurts ta check em again. ill post if problem persists....thx jack |
New member Username: Dave_h
Post Number: 3 Registered: 01-2004
| Posted on Thursday, January 29, 2004 - 12:01 pm: |
I have heard that Samsung equipment works best and does not have the green tint when using DVI connections (rather than S-video or component) between the various video components. |
Post Number: 7 Registered: 12-2003
| Posted on Thursday, January 29, 2004 - 02:31 pm: |
ok what is dvi setup? im using component setup cables. |
