Thread: 5.1 analog connection |
Unregistered guest |
| Posted on Friday, October 22, 2004 - 08:35 pm: |
I have always used the optical connection on my DVD player and reciever, but recently with all the talk of DVD-A and SACD i connected my 5.1 analog inputs. My question is, is it common that when listening to a DVD in the analog 5.1 mode to lose a lot of bass from the track. It seems as though my sub is almost non existant with the 5.1 analog connections unless I turn the sub volume all the way up. Everything else is crisp and sharp and the connection still decoded DD and DTS, just have a problem with the bass sounds. Is this common? |
Bronze Member Username: Forcedinduction
Post Number: 44 Registered: Sep-04
| Posted on Saturday, October 23, 2004 - 02:48 am: |
You're using the D/A converter on your DVD player now, it may not be as good as the one in your receiver. You also have to have better cables, because your DVD player's output is analong instead of digital. Overall the optical connection is a better bet for DVD players, but due to copyright laws, DVD-A and SACD must be output via analog <--that really pisses me off. |
| Posted on Saturday, October 23, 2004 - 08:55 am: |
thank you for the info. That makes sense. I always thought a digital connection would be superior to analg, thats why I couldnt figure all the hype to SACD and DVD-A through analog. Im sure they are good, but not digital quality. I just wasnt aware of the copyright. thanks |
Post Number: 51 Registered: Sep-04
| Posted on Saturday, October 23, 2004 - 10:52 am: |
They think that you're going to digitally copy their music and make true 1:1 copies. What is pitiful though, is that I can take that dvd-a and put it in my computer and do exactly that. Morons |
Bronze Member Username: Sandiego
Post Number: 34 Registered: Oct-04
| Posted on Sunday, October 31, 2004 - 12:54 am: |
I'm trying to understand this. I have a DVD audio disk and I can play it on my dvd player running an optical cable to my receiver. When I do that the receiver reads "Digital." So is it not really in 5.1? do I need to use the analog multi channel inputs and outputs to fuly enjoy dvd audio and SACD? |
JamesCB Unregistered guest |
| Posted on Thursday, November 04, 2004 - 04:22 pm: |
Yes, you MUST use the 6 analog outputs from the player to get SACD and DVD-A. James |
| Posted on Friday, November 19, 2004 - 12:38 pm: |
baire, There are some SACD/DVD-A players that have very low sub output. The sub output on my universal player is about 10 dB less than the other channels. You will need to calibrate your system by ear or with a SPL meter to balance the levels of all your speakers. I also want to reiterate what James said. If you are using the digital connection for your DVD/SAC-D player, you are NOT getting high-res audio. And for multi-channel discs, you are not getting the true multi-channel output, although you may think you are if your receiver is using Pro Logic or some other DSP mode, which will be inferior to the multi-channel high-res track. --Nathan |
Gold Member Username: John_a
Post Number: 2474 Registered: Dec-03
| Posted on Saturday, November 20, 2004 - 12:03 am: |
baire, At a rough guess, you may have grown accustomed to hearing the low frequencies reproduced twice, with an active sub plus large front speakers. I find Dolby Digital AC-3 (5.1) does that when my receiver decodes it (with digital input) but not when my player decodes it (that is when using 5.1 analogue out). DTS does not do it, in any case. On my system, everything sounds better using the analogue 5.1 connections, even plain stereo CD. |
