Thread: Def Tech |
New member Username: Eubanks01
Post Number: 1 Registered: Oct-04
| Posted on Wednesday, October 20, 2004 - 06:12 pm: |
Should I bi-wire or tri-wire my Def Tech CLR 2500 center and BP2002TL towers? Does it make it really sound any better? Thanks! |
Post Number: 1725 Registered: Dec-03
| Posted on Thursday, October 21, 2004 - 06:17 am: |
Different people claim different things, and sometimes these differing opinions get heated. Experiment and try it out for yourself and see if YOU hear a difference. |
Post Number: 2 Registered: Oct-04
| Posted on Thursday, October 21, 2004 - 09:58 am: |
Ok, I just didn't want to spend the money if it wasn't going to make a difference. Does anyone know how I should do this and split the wire going to the speakers? Thanks Berny. |
Post Number: 1729 Registered: Dec-03
| Posted on Thursday, October 21, 2004 - 03:21 pm: |
There are speaker cables that are bult for this purpose, but you can do it on your own. You have to remove the jumpers then run your speaker wires form the receiver to the speakers and split them at the terminals. You can also run 2 sets of wires. |
