Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through October 26, 2004 > Did I make the right choice?
Author Thread: Did I make the right choice?
Username: Juitzhead
Hello All,
Im VERY new to the home theater market and would like some general advice. I just purchased a Yamaha RX-V750 receiver and a Jamo A310PDD.1 speaker system.
The only thing that worries me at the moment is if the speakers will be able to keep up with the receiver in terms of performance (they wont blow up or something drastic like that).
I specifically mentioned the receiver model to the sales guy and he suggested these speakers would be suitable for the price range.
Can anyone think of a reason for me not to keep the speakers?
thanks!
Username: Project6
Post Number: 1716
The only reason not to keep them would be, that you don't like the way they sound. Your worries are indeed drastic.
If you like the sound keep them, if not, audition new ones, after all, you will be the one listening.
cheers
Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through October 26, 2004 > Did I make the right choice? [ « Previous ] [ Next » ]
