Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 26, 2004 > Crossover/Sub problem
Author Thread: Crossover/Sub problem
Alright so I bought a surround sound for my computer. It's a creative labs 5.1 and my roomate at some time or other managed to kick the subwoofer and put a hole in the cone. My question is this. Should I buy a new sub (it was a 3.5" one) or should I try to affix a new one to the system all together. What I mean by this is go for something bigger like an 8inch or 2 8inch ones. My main question is this, if i were to go bigger then how would I go about using the crossover located within the sub box because I know absolutely nothing about crossovers. Could I even use the same one? Currently there is just one in the ported sub box that operates the 5 speakers and subwoofer. Thanks alot,
Garrett
~If it all possible email answers directly to my email - - Gkittels@nebrwesleyan.edu
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 26, 2004 > Crossover/Sub problem [ « Previous ] [ Next » ]
