Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 26, 2004 > Recommendation for an A/V reciever
Author Thread: Recommendation for an A/V reciever
Seb
Hello
I want to go all digital.
I have a Sony VPL-HS20 projector (http://www.projectorcentral.com/Sony-VPL-HS20.htm), which has DVI input. I want to connect 2 computers, a HDTV tuner, and a DVD player all to this projector. (they all have DVI output)
The 2 computers, HDTV tuner and DVD will also output digital 5.1 sound so 4 SPDIF/Coax/optical sound inputs are also needed.
I have not however found an A/V reciever that has 4 DVI inputs, and an DVI output. I have found a reciever with component inputs and outputs - but i'm intent on going all digital.
Does anyone know anything that will suit me?
Thanks,
Seb
Username: Toon
Post Number: 10
You can find a DVI switch @ this website: http://www.pacificcable.com/DVI_Switch.html
I haven't seen an A/V reciver that has the ability to switch 4 DVI sources. Hope this helps.
Seb
Thanks. Getting a reciever will save me a lot of money, as I cant afford to get everything separately.
I think i'll wait until something comes out. They're sure to come out, and it can't be too long now!
If anybody had any news on this (plans, dates), please post it.
Seb
Username: Forcedinduction
Post Number: 21
Prepare to spend a lot of $$ to do what you're looking to do.
The DENON AVR-5805 can do what you want if you buy DVI->HDMI converters...
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 26, 2004 > Recommendation for an A/V reciever [ « Previous ] [ Next » ]
