Thread: $1000 |
New member Username: Bable
Post Number: 4 Registered: Oct-04
| Posted on Thursday, October 14, 2004 - 01:19 pm: |
If I have $1000 for my budget, what would you recommended? I want all the set that buy it by seperate. Another thing, Is Energy take 5.2 good? Thank you |
Scotty2Hotty Unregistered guest |
| Posted on Thursday, October 14, 2004 - 09:16 pm: |
I want all the set that buy it by seperate. ??? |
Post Number: 5 Registered: Oct-04
| Posted on Thursday, October 14, 2004 - 09:27 pm: |
buy separate
Bronze Member Username: Forcedinduction
Post Number: 28 Registered: Sep-04
| Posted on Saturday, October 23, 2004 - 02:04 am: |
Klipsch has some pretty sweet new 5.1 setups. You'll have to check local prices but the Klipsch Cinema 6, 8 and 10 are quality units. As well as the RB-10 and RF-10 systems. Denon receivers match well with klipsch equipment because they tone down the "brightness" of the klipsch speakers. Find a local dealer and listen to some different equipment. I beleive HT is about what sounds best to you, not somebody else. Personally, I LOVE the way the klipsch horns sound. |
