Thread: TV as center channel? |
New member Username: Erknjerk
Post Number: 5 Registered: 01-2004
| Posted on Wednesday, January 21, 2004 - 01:41 am: |
Can you use the TVs speakers as the center channel? If so do have to open it up and wire it in? |
New member Username: Project6
Post Number: 108 Registered: 12-2003
| Posted on Wednesday, January 21, 2004 - 01:48 am: |
unfortunately yes, I won't recommend it though
Post Number: 6 Registered: 01-2004
| Posted on Wednesday, January 21, 2004 - 01:58 am: |
Ok. |
New member Username: Medpilot
| Posted on Saturday, January 24, 2004 - 08:50 pm: |
I have a JVC AV-65WP74 and it comes with the option to run the main TV speakers as the center channel(can be set up in the on-screen menu). Normally I would say this is a bad idea, but the sound that comes from the stock TV speaker is amazing(for a TV). I'm going to try this when I get receiver and I'll post my results. |
Unregistered guest |
| Posted on Tuesday, September 07, 2004 - 04:22 pm: |
I have a Samsung HL-P6163W. I would like to pursue using the TV speakers as the center channel. My Sony surround receiver has left and right speaker outputs and a subwoofer output, but the only center output is the amped speaker wire. Has anyone found a way to wire the TV speakers as center channel. Thanks! |
Bronze Member Username: Jdsaenz1
Post Number: 58 Registered: Jun-04
| Posted on Friday, September 10, 2004 - 05:53 pm: |
Mine is a cautionary tale: whatever you do, don't try and engineer your own connection to your tv. As much as I wanted to use my tv speakers as the center channel, I was impatient and foolish. My center channel out to center speaker is speaker wire, but the audio input on the tv is rca-style. I tried combining spliced rca-type audio cables to the speaker wire , and ended up blowing the fuse for the center channel. Now I have NO center channel until I replace the fuse. Bummer! |
