Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 26, 2004 > Comcast hd / digi cable with pioneer ...
Author Thread: Comcast hd / digi cable with pioneer vsx-d711
Username: Tjohn
Hello, sorry if this is a clueless question but.... I'm finally getting digital cable with hdtv tomorrow and I have a question about the hook up through my receiver. Will the cable guy have the cables I need, and if not what should I buy? I want to be able to have the best sound while watching hdtv.
TIA
John
Scotty2Hotty
I'm sure they will bring everything you need to hook it up (the guy won't leave with it not working).
I am also sure they won't be the same quality as the monster cables.
Username: Tjohn
Yes, just got it all hooked up and comcast actually supplied an optical cable! I'm good to go :-) He did say that if I wanted to listen to sound through my a/v receiver I should completely disable my tv's main speakers. Why can't I just mute it or turn it down all the way?? I'll fiddle with it later tonight.
Scotty2Hotty
That's what I do... I turn it down all the way because muting it puts captioning on and I'm too lazy to disable it.
Username: Tjohn
Yup! Worked great last night. Love the digital sound on the HD channels :-) I can buy any good quality component video cable for it right? The one they supplied is only 4' long so I can't put the STB where I want.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 26, 2004 > Comcast hd / digi cable with pioneer ... [ « Previous ] [ Next » ]
