Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 30, 2004 > Subwoofer wiring.
Author Thread: Subwoofer wiring.
Username: Emkmd
Post Number: 18
Hi,
I want to do in-wall wiring for a subwoofer. I have read that I can use regular coax, is this possible. My current cable, is directional. Would the coax need to be directional as well? Help appreciated.
Username: Project6
Post Number: 107
can you elaborate on that directional cable??
And yes you can use regular coax.
cheers
Username: Emkmd
Post Number: 21
Thanks Berny,
My current Monster subwoofer cable has small directional arrows on it. THey are supposed to point from the receiver to the subwoofer.
-E
Username: Project6
Post Number: 114
aaah, the olde arrows in the cable thing...very interesting. I have those on my cables too, I use monsters a lot...cosmetic and price reasons, I can get 'em real cheap.
please, don't take it the wrong way but you may want to check out this article
http://www.audioholics.com/techtips/audioprinciples/interconnects/audiocablesrel igion-or-science.html
cheers
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 30, 2004 > Subwoofer wiring. [ « Previous ] [ Next » ]
