Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 26, 2004 > Help me to configure Optical setup.
Author Thread: Help me to configure Optical setup.
Username: Citsathish
Jersey, NJ
US
Post Number: 12
I am using yamaha rxv-640 home theater system. I was trying to see the quality of sound difference between the optical output and the coaxial one.
I first connect my DVD's audio output to receiver's DVD input later
i connect the DVD's optical output to receiver's optical input...meanwhile the audio output of my DVD cable also still connected. becos if i disconnect it then there is no audio.
The problem is i could find any bright difference in optical connectivity.
Is this a very mild difference in output clarity with the optical output. I tested the movie "Lord of the Ring"...
please help me to configure my optical setup.
Scotty2Hotty
I thought there was no difference in sound quality between opt. and coax...
Kruz
yes there is a difference.......but ONLY when u get into 9.1++(parralell not actually 9.1 just emulation) optical is better....but for just ur everyday home theatre system go digital coax
1 reason
its cheaper :D
Username: Project6
Post Number: 1660
if you disconnect the audio output of the dvd player and there is no sound...here's a clue...the optical output is not working!
Jersey, NJ
US
Post Number: 13
Berny....are you sure the optical output is not working that if i disconnect the audio output from the dvd player and only the optical output of dvd palyer is connected to receiver.
if suppose the problem with optical output then how to resolve it..is there any problem with cable incompatible..? Mine is sony DVD player but i am using audiotechnic optical cable.
Username: Project6
Post Number: 1724
Try getting a new optical cable. If it is broken, you can't resolve it.
Check the configuration of your DVD player if it is set to output digital audio.
Username: Forcedinduction
Post Number: 22
There will be no difference in sound. The EXACT same signal is being decoded using your D/A converter on your receiver.
For example:
If the optical cable sends 1010111 to the receiver the digital coax also sends 1010111 to the receiver. You cannot get anything different using DIGITAL signals.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 26, 2004 > Help me to configure Optical setup. [ « Previous ] [ Next » ]
