Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 26, 2004 > Speaker placement 5.1 in combo living...
Author Thread: Speaker placement 5.1 in combo living/dining room
Username: Edcroteau
Any suggestions on placement of my Front Right and Surround Right speakers. The entertainment center and viewing sofa occupies only 1/3 of the room with the center 1/3 being the fireplace and the last 1/3 being the dining room table. Should I place the right speakers the same distance from the TV/center as the left speakers or all the way to other side of the room above the dining room table side (wall mounted bookshelf or smaller sized speakers). I will use a Velodyne SPL-800 or 1000 for the sub, Denon 3805 A/V surround receiver, and Denon 3910 universal player. Considering the Boston Acoustics 130x series and the Totem Acoustics Dreamcatcher 5.1. Any thoughts on that ? I need to keep the speakers as small and unobtrusive as possible but don't want Bose cubes.
Scotty2Hotty
I think a good rule of thumb is to place the front speakers 25-30 degrees away from the TV.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 26, 2004 > Speaker placement 5.1 in combo living... [ « Previous ] [ Next » ]
