Thread: Very basic question |
| Posted on Thursday, September 30, 2004 - 09:56 am: |
to get Dolby Digital and DTS effects, i'm assuming you have to use the optical in/out on the receiver/DVD player with an optical cable. otherwise, how would you get full 5 channel separation if you used the red/white analog RCA cables. is this correct? does the video go through the optical port as well? thanks. |
Post Number: 1583 Registered: Dec-03
| Posted on Thursday, September 30, 2004 - 12:42 pm: |
You have to use the optical/digital in/out or if you have 6 channel analogue you can get the separation as well. The red/white analogue is for stereo separation or pro logic applications. No, the video does not go to the optical port. You have to use video inputs on your receiver or TV, via composite, s-video or component.
| Posted on Thursday, September 30, 2004 - 01:42 pm: |
Thanks! i appreciate it. any opinion on which is better, optical or digital coax? |
Post Number: 1585 Registered: Dec-03
| Posted on Thursday, September 30, 2004 - 02:47 pm: |
People have their preferences. Neither is bad! |
