Home > Message Board > Home Theater > Surround Sound > Archive through December 27, 2004 > Rear surround speakers not distinct
Author Thread: Rear surround speakers not distinct
Username: Jhunt15
I have a sony HT-DDW740 reciever with 5.1 setup using infinity TSS-750 speakers. I have noticed a "smaller" sound lately (while watching SW Trilogy). The THX setup on the discs revealed that the sound from the rear speakers is not separate...seems to be sound emanating from the left when it should be only the right. Wiring appears correct. It should be noted that this doesn't seem to be the case with DTS DVD's. They sound spectacular. ALso of note I am using Xbox as DVD player with monster cables. ANy ideas.
thanks
Username: Project6
Post Number: 1527
Do you get these problems on other discs? If not, it's the disc.
Username: Jhunt15
Yep, same problem with other DD discs. As I said I don't seem to have problems with DTS format, they sound great.Any Ideas?
Thanks
JH
Username: Project6
Post Number: 1584
Check the set-up of the DVD player regarding audio outputs. I'm stumped:-(
Home > Message Board > Home Theater > Surround Sound > Archive through December 27, 2004 > Rear surround speakers not distinct [ « Previous ] [ Next » ]
