Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through October 26, 2004 > JBL SCS115 Speakers - Any Good?
Author Thread: JBL SCS115 Speakers - Any Good?
Username: Os2dude
Marietta , GA
Post Number: 7
I have an old JBL SCS115 Surround Sound speaker set that I bought with a re-manufactured JVC 664R(?) receiver. The fronts plug into the sub-woofer, and the L/R from the receiver plug into the sub-woofer as well. After a few days the receiver blew a couple of power transistors (?). After spending big-bucks to get it fixed, I bought a couple of JBL J900VM speakers and put the SCS115 in a closet.
Now I'm thinking of getting a Yamaha RX-V2400, and I want to use the speakers from the SCS115 as my surrounds. (Don't know about using the Sub any more. . .) However, I don't want to blow the Yamaha either.
Any ideas on the initial problem? Thought on what I should check before hooking them up?
Thanks
Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through October 26, 2004 > JBL SCS115 Speakers - Any Good? [ « Previous ] [ Next » ]
