Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 30, 2004 > Which radio shack SPL meter
Author Thread: Which radio shack SPL meter
Username: Disco_stan
Post Number: 45
I heard that the 7 range analog display sound level meter is recommended over the 10 dollar more expensive, Digital-Display Sound-Level one. Any advantages to the analog one? Or the digital one?
howlswolf
i just bought the digital one .. i have yet to play with it. Im looking for a site that i have lost the link where they were saying the db difference you should have for all speaker ..
Post Number: 46
When you find that, let me know.
howlswolf
found part of it
http://emusician.com/ar/emusic_mixing_budget/index.htm
howlswolf
this is also where i first heard of the radio shack SPL meter :-) kinda hard to calibrate my 7.1 without one since my room is not *perfect*
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 30, 2004 > Which radio shack SPL meter [ « Previous ] [ Next » ]
