Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through February 18, 2004 > Best Speaker Systems Under $600
Author Thread: Best Speaker Systems Under $600
jimmylh
Hi anyone have any suggestion for HT Speaker systems under $600 for Denon AVR1803 or Yamaha Rxv640?
I need to use the systems mainly for music (modern jazz)
I've tried Bose Accoustimass 10 but the sound for music was so awful for the $900 price tag.
Thanks Heaps.
Username: Project6
Post Number: 75
are you looking at 5.1 systems? A great option is the Fluance SX-HTB for $259 and their sub DB150 for $199. A really great system if you are just starting out.
I have auditioned the system and it sounds great paired with the Yamaha. I am also impressed with the build quality!
cheers
Username: Edison
Post Number: 263
http://cgi.audiogon.com/cgi-bin/auc.pl?spkrfull&1074049589
Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through February 18, 2004 > Best Speaker Systems Under $600 [ « Previous ] [ Next » ]
