Home > Message Board > Stuff for Sale > Rockford Fosgate p8002 AMP w/ bass kn...
Author Thread: Rockford Fosgate p8002 AMP w/ bass knob ***800 RMS*** $180 Shipped
Username: Jesseixe
Post Number: 14
. Product:
2. Specs:
Details:
2-channel car amplifier
200 watts RMS x 2 at 4 ohms (400 watts RMS x 2 at 2 ohms)
800 watts RMS x 1 at 4 ohms (4-ohm stable in bridged mode)
variable high-pass/low-pass crossover (40-400 Hz, 12 dB/octave)
variable remote Punch Bass boost (0-18 dB at 45 Hz)
Tri-way capable (Tri-Way crossover required)
MOSFET power supplies and output stages
CEA-2006 compliant
preamp-level inputs
preamp outputs
fuse rating: 40A x 3
4-gauge wiring kit and 150-amp fuse recommended — wiring and hardware not included with amplifier
17-5/8"W x 2-1/2"H x 11-5/16"D
3. Description/Condition:
WORKS GREAT!!!
Used ROCKFORD FOSGATE P8002 AMP include's remote bass knob,wire & Kicker 150 amp fuse!!
Don't let your sound system dance around the ring; fire up a Punch series amplifier from Rockford Fosgate and enjoy a knockout performance every time! These amps will sting your speakers with plenty of clean power, while serving up the sound-shaping controls and high-quality components you need to create a heavyweight audio system.
A cut above, the Punch P8002 delivers a stout 200 watts RMS per channel in stereo mode (plenty for a set of power-hungry component speakers, or a couple of subwoofers), or a hair-raising 800 watts RMS of clean power in bridged mode. The innovative circuit design, MOSFET output stages, and proprietary technology inside the Punch P8002 bring out extraordinary detail and impact in your music, with ultra-clean power you just can't get from a lesser amp.
The pros at Rockford Fosgate know that it takes more than just muscle to create a prize-winning car audio system. So, the P8002 is equipped with variable high- and low-pass crossovers — which help maximize performance by sending your speakers only the frequencies that they're designed to handle — and a Punch Bass boost (0-18 dB at 45 Hz) with wired remote for hands-on control. You choose the right settings for your car, your speakers, and your ears.
4. Price: :
180 SHIPPED
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Stuff for Sale > Rockford Fosgate p8002 AMP w/ bass kn... [ « Previous ] [ Next » ]
