Thread: Mpyre Audio 65M Component Speakers 6.5" ( Adire Extremis ) $99 Shipped |
New member Username: 501courtneyk
Little Rock,
AR
Post Number: 1 Registered: Jan-09
| Posted on Saturday, January 24, 2009 - 09:59 pm: |
http://www.jackstoneusa.com/img/single.jpg I have bought the remaining stock of these speakers. I am user 501courtneyk on eBay if you want to check my feedback. This is 1 pair of component speakers. They are new in the original boxes. They are $99.00 shipped anywhere within the US. This is 1 Pair of Mpyre Audio 65M mid-woofers along with matching crossovers. To make this clear that is two 2 65M midwoofers and two 2 custom crossovers. They are designed to be paired with a (NOT INCLUDED) silk dome tweeter. They have awesome sound quality and provide unequaled bass despite their small size. Many customers opt to not use a subwoofer as the extension and excursion of these drivers is incredible. These are the legendary Adire Extremis with a carbon fiber cone and an M silkscreened on it w/ stronger, more rigid baskets! Check out the reviews online...these are the best there is! Here are the specs: Patented XBL^2 Motor Fs: 35 Hz Qms: 2.8 Qes: 0.48 Qts: 0.41 Vas: 23 liters Re: 3.50 Ohms Le: .005 mH BL: 6.13 Mms: 23 grams Sd: 140 cm^2 Cms: 0.5 mm/N XMAX: 13mm XMECH: 15mm Depth: 3 1/2" Pwr Handling: 150WRMS Single 4 Ohm Voice Coil and of course world class build quality! Text From the website: Our 65M midbass has the presence and sound quality to make any installation sing. Based on the legendary Adire Audio Extremis only customized and stylized for the car audio environment. This is simply the most beautiful sounding midbass available, with plenty of excursion for low-end kick and an ultra flat BL curve, the 65M is the driver every car audio enthusiast has been waiting for. The 65M features XBL^2 motor technology, a vented, eight spoke European cast aluminum basket, dry carbon fiber cone, 4 layer 38mm copper voice coil using an aluminum former, stacked NEODYMIUM magnets and of course world class build quality! http://www.jackstoneusa.com/img/65m1.jpg http://www.jackstoneusa.com/img/65m2.jpg http://www.jackstoneusa.com/img/65m3.jpg http://www.jackstoneusa.com/img/65m4.jpg http://www.jackstoneusa.com/img/65m6.jpg |
