Home > Message Board > Stuff for Sale > Mtx 81001d amp 4 Sale
Author Thread: Mtx 81001d amp 4 Sale
Username: Legend_rider
Metairie, Louisiana
United states
I recently purchased this amp at the end of February 2008 for about $450 only used it for about 3 or 4 months still in like new condition accept for a few marks on it. Hasn't been repaired and not a refurbished amp have the original box and all accessories to go with it spec sheet bass knob and etc. Askin atleast $300.00 or best offer
Username: Steveyhustle
Rancho Cucamonga, CA
Post Number: 7
specs?
Metairie, Louisiana
United states
HERE ARE THE SPECS FOR THE MTX 81001d amp
Click For More Images
Click for more Images
Quick Install Settings
Quick Install Wiring
Owner's Manual
StreetWires
Amplifier Dimensions
TA81001 Specifications
# of Channels 1
Minimum Single Channel Impedance 1
Class D (Patented Adaptive Class D)
(Pat. No: US06753729) x
Amp Type Optimized for Subwoofer x
Power Supply Semi Unregulated MOSFET
(Pat. No: US05598325) x
THD + Noise (1 Watt) 0.5%
Signal-To-Noise Ratio (1 Watt) 68 dB
Overload Protection x
Thermal Protection x
Xtant Technology Cooling Continuously Variable Fan Speed x
Connection Terminals StreetWires Connectors x
14.4VDC Power 4 Ω 500W
2 Ω 1000W
1 Ω 1500W
4 Ω (Two Amps Strapped - wattage is combined power from both amps) 2000W
2 Ω (Two Amps Strapped - wattage is combined power from both amps) 3000W
INPUT (RCA Connection) Low Level x
Hi Level w/ Smart Engage (Pat. No: US06556683) x
INPUT SWITCH Input Sense 100mV-1V/1V-10V x
GAIN CONTROL Mono - 100mV-10V x
CROSSOVER Low @ 40Hz-200Hz, 24dB x
SubSonic @ 20-50Hz, 12dB/oct x
EQUALIZATION Parametric: Boost/Cut +/-12dB, Freq. 30Hz-80Hz, Q 0.5-4.0 x
OTHER FEATURES Remote Subwoofer Level Control Parallelable x
Phase: 0 or 180 x
FUSE RATING Total 160
Quantity x Fuse Value 4 x 40
DIMENSIONS Width 20-11/16"
Depth 9-5/8"
Height 2-1/2"
MONO-BLOCK
TA92001
TA81001
TA7801
2-CHANNEL
TA91002
TA8502
TA7402
4-CHANNEL
TA7804
ThunderTA
Super Amp Main
Compare Super Amplifiers
Match TA Amps
to Subwoofers
Match TA Amps to
SledgeHammer Enclosures
Match TA Amps
to Speakers
Thunder Amplifier Dyno Certificate
©2008 MiTek. All Rights Reserved.
NEWS · SUPPORT · WHERE TO BUY · ISO 9001 CERTIFIED · CONTACT
Post Number: 8
Hmm honestly cant really understand those, whats the amp do 1x@2ohms ?
Metairie, Louisiana
United states
the amp does 1000 watts rated and 1516 watts measured @ 2 ohm and at it does 1500 watts rated and 1871 watts measured @ 1 Ohm
Username: Mike_16
Reedsburg, Wisconsin
Us
Post Number: 1051
still for sale?
Metairie, Louisiana
United states
Post Number: 7
yes it is are. you interested in buying it?
Username: Teamdeboy1971
OPTIDRIVE LN. La F..., TN
Major Bass P...
Post Number: 549
Is this amp still for sale?????
Username: Mike_16
Mauston wi, Wisconsin
Us
Post Number: 1109
is the amp still for sale??????
Username: Mariano_831
do you know if this amp can handle 18 volts?
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Stuff for Sale > Mtx 81001d amp 4 Sale [ « Previous ] [ Next » ]
