Home > Message Board > Stuff for Sale > 15" Orion Hcca for Sale
Author Thread: 15" Orion Hcca for Sale
Username: Legend_rider
Metairie, Louisiana
United states
I have a 15" orion hcca DVC 2Ohm for sale with box will let go for reasonable price cost $699.00. Purchased It in march of 2008 barely used. If interested leave me your email address for pics to be sentUpload
Username: Loudon
Post Number: 2649
hmm try again on that price ...
Metairie, Louisiana
United states
$699.00 is not the price i'm selling it for. Make offer
Metairie, Louisiana
United states
specs for orion sub
Orion HCCA-15.2
ORION HCCA 15" 2 OHM SUBWOOFER
seperator
So you want the best in a SPL woofer? Well, look no further. The new Orion HCCA subwoofers are the baddest subs on the planet. Hands down. You could call our HCCA sub a “super woofer”, but really it's the superior woofer! With its massive 4" high temp voice coil and immense motor, this subwoofer can reach as much as 4" of travel. And everyone knows that more travel equals more BASS!
seperator
features
4” copper Wound Voice Coil on an Aluminum Former, High temperature PAARC (Polyester Amide, Amide Resin Coated)
Continuous power handling will be 1500W (under rated)
Peak power handling: 10” 3000W 12 & 15” 4000W
Burp power in excess of 4000W on 10” and 5000W on 12 & 15”
X-Max estimated at 30mm (total travel 4” peak to peak)
Field Replaceable Cone / Voice coil / Spider Assembly
Dual Flat Conex Spiders with Loop/Stitched Tinsel Leads
Tall, wide, balanced, Foam (high density expanded polyester foam) surround for linear controlled long excursion using a Tri-Radius symmetrical edge design optimized on non-linear FEA
Enhanced voice coil cooling system (forced convection – aluminum heat sinking – shorting rings to reduce inductive heating)
[contract] specifications
Model Number HCCA 15.2
Power(RMS/Peak) 2000/4000
Fs (Hz) 33
Qts .6
Vas (cu ft) 2.648
SENSITIVITY 87db
LINEAR EXCURSION 30mm
DIMENSIONS (in) 15.6x12
[expand] specifications
Owners Guide
(3/27/2007)
Username: Loc_out
SOCAL
2 RE 15 XXX
Post Number: 2435
Good luck on that sale bro
Username: Myhcca15
Statesville , Nc
sweet sub i have one my self
http://i435.photobucket.com/albums/qq71/BMARIE714/Orion%20HCCA%2015/100_2035.jpg
Username: Myhcca15
Statesville , Nc
hit a 140.6 on tl at the head rest with only 800 watts
Username: Myhcca15
Statesville , Nc
free
bump
Username: Caesar1212
Brandon, Fl
Post Number: 62
$1?
sounds fair to me
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Stuff for Sale > 15" Orion Hcca for Sale [ « Previous ] [ Next » ]
