Thread: Kicker kx450.2 trade for a amp that does 400 or more rms@2ohms |
Silver Member Username: Dirtrider125
Post Number: 103 Registered: Apr-07
| Posted on Wednesday, May 07, 2008 - 03:24 pm: |
i need a amp that does 400 or more rms @ 2 ohms i will trade a kicker kx450.2 because i thought i was gettin a dual 4 ohm type r and i read it wrong its a dual 2 ohm so now i need to change amps i really want a kicker 400.1 |
Relevant Product Info
Gold Member Username: Southernrebel
Monroe,
Louisiana
2 DD3515s, 2...
Post Number: 6380 Registered: Mar-04
| Posted on Monday, May 12, 2008 - 02:08 am: |
You do know...a dual 2ohm sub can be wired to 4ohm. ??? |
Post Number: 138 Registered: Apr-07
| Posted on Monday, May 12, 2008 - 12:28 pm: |
yea i meant to say i thought it was dual 2 ohm but its dual 4 ohm |
Silver Member Username: Snowball123
West Allis,
WI
United States
Post Number: 650 Registered: Oct-07
| Posted on Wednesday, May 14, 2008 - 05:09 pm: |
wait isnt the amp put its most power at 2 ohms anyways? then wire the dual 4 to 2 ohms. |
