Home > Message Board > Off Topic > H.I.D. high/low beam relay
Author Thread: H.I.D. high/low beam relay
Username: Shortysetnies
Andrew Capps, NC
US
Post Number: 3407
No, I do not have projectors retro fitted just stock, OEM, Nissan frontier headlights. I need no flaming of the sort. Leave it out of the thread...
I just upgraded my single beam HIDs to high/lows last night and I have a little problem. The high beam from my stock harness sends out a low amount of voltage whenever the headlights are on low or high, according to the DMM, which is triggering my high beams to stay on at all times while the plug is connected.
I can run just my lows if I unplug the harness that triggers the magnet/relay for my high beams but then I cannot run high beams. I cut the harness and hard wired the high beams on a switch just to make sure the HID kit worked fine, and it does. Switch the power on and high beams, off and back to lows...
I dont want to have a rocker swich on my dash for my high beams but I want to be able to use them when Im on back roads (where I drive 95% of the time).
Anyone have a solution? If I wire up another relay, straight from the factory wiring to the headlight, bypassing the ballast, it would act the same because of the constant voltage from the OEM wiring... Im lost.
Andrew Capps, NC
US
Post Number: 3408
anyone?
Username: Pitbullguy
The Chicago area
Post Number: 4011
I had a flashlight stop working once even though the batteries were like brand new. I had to remove the cover from the battery compartment, and wiggle them around a little. Flashlight worked fine after that.
Hope this helps, good luck.
Username: Livin_loud
COD4 Addict
Post Number: 2955
lol
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Off Topic > H.I.D. high/low beam relay [ « Previous ] [ Next » ]
