Home > Message Board > Off Topic > Brad please fix my computer
Author Thread: Brad please fix my computer
Username: Ween2ween
Everytime I try to open Firefox even after reinstallation, I get a closed Firefox prompt. The prompt says it is already in use or unresponsive. I've tried deleting and reinstalling it, and I get the same message.
With Internet Explorer, I get a repeating message it says I.E. has to close then I press Ok. Then it says the tab has been recovered. I basically cannot go to any other website when this happens. I have run avg, Windows Defender, and Housecall trendmicro and I cannot find any viruses or spywear. With avg I get warnings in application data folder for Firefox when Firefox is installed. When I manually delete those warnings there's no difference.
I've tried deleting the cookies and that does not work. Can you please help me and tell me what is wrong with my computer? I am posting on a different computer. By the way this is Thieves.
Diamond Member
Post Number: 23455
brad my fire fox freezes when i go in to certain websites. its usually the sites that have pop ups. how can i fix this?
where are you brad warren?
Username: Big_edge_head
Milwaukee, WI
Post Number: 4052
Try using Opera.
Diamond Member
Post Number: 23459
is your name brad? lol
Milwaukee, WI
Post Number: 4054
Diamond Member
Post Number: 23460
lol steve. you know you my boy. lol.
i just miss brad's tech advices. lol. its been awhile since i got one from him.
Username: The_image_dynamic
San Diego, California
Post Number: 5303
I have been really busy guys -- sorry.
Thieves uninstall Firefox and install an older version from here:
http://www.oldapps.com/firefox.php
For your IE issue you need to disable script debugging:
Start Internet Explorer.
On the Tools menu, click Internet Options.
On the Advanced tab, under the Browsing section, click to select the Disable script debugging (Internet Explorer) check box and the Disable script debugging (Other) check box if it is present.
Click OK, and then restart your computer.
Chad, sounds like a glitchy install. Uninstall and then install the newest version and you should be ok.
http://www.mozilla.com/products/download.html?product=firefox-3.5.2&os=win&lang= en-US
Username: Ween2ween
Post Number: 7
I'll try that but I still have a virus involving the cookies that I can't seem to find. I'm on bleepingcomputer.com posting a DDS log just to see if they can diagnose my problem.
-Thieves
Diamond Member
Post Number: 23464
thanks brad. i need to buy a laptop asap so i can get on aim and chat with you guys sometime when you are not busy and all.
also i didn't know ween was thieves. hahahaha. wtf is up man? how you been? you don't even text no more.:-(
Milwaukee, WI
Post Number: 4059
Did you forget your password or something, Thieves? lol
Diamond Member
Post Number: 23472
steve the jerk store called. they said they are running out of you. lol.
Milwaukee, WI
Post Number: 4064
Whats the difference, you're their all time best seller!
Username: Ween2ween
Post Number: 8
No, I can't get on my computer so I asked my girl to sign on her account to help me out.
Username: Jtown
Texas
Post Number: 3903
I can't visit ecoustics on my comp, because IE constantly "recovers the tab," so much so that I can't navigate to any other site. I have to close the browser and open a new window.
if you're not helping, please don't post, that opera post was useless.
Brad I have yet to try what you suggested, I haven't been near my comp lately..
Anyway, in my cookies, I have several threats, but I noticed the common ones seem to be tied to pop ups, I can't remember all of them, but the two I remember are "adbrite" and "doubeclick"
I ran spybot, and spyblaster, removing the threats through the program, and I also tried removing them manually, but they refuse to go away.
Any suggestions? BTW, I really appreciate the help, especially since you mentioned being busy.
Thanks again.
Milwaukee, WI
Post Number: 4072
Geeezzz, well sorry.
Post Number: 5306
Get KillBox here: http://download.bleepingcomputer.com/spyware/KillBox.exe
Do your scans, write down the file names and locations, add them all to KillBox and check the "Delete on reboot" box. Reboot.
Username: Mrskullz1
Brooklyn, New York
Post Number: 1217
IE used to do the same to my ecoustics page. I installed flash player and it never seemed to happen again.
Not sure if this is the solution but just putting it out their.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Off Topic > Brad please fix my computer [ « Previous ] [ Next » ]
