Home > Message Board > Off Topic > How to convert swf to avi with iwisoft?
Author Thread: How to convert swf to avi with iwisoft?
Username: Lynki2009
Would you like to convert funny flash swf to avi format video files?
o(กษ_กษ)o...
No hesitate, just use the iwisoft flash swf to video converter, which can easily help you finish your converting.
More information: http://www.flash-swf-converter.com
Steps:
1). Download and install the iwisoft flash swf to video converter.
2). Input Flash SWF file from local computer.
3). Click the "Settings" button. Under the "Output Format" tab, select "AVI/XVID" as the target. You can choose a video profile or customize the video and audio parameters as you like. Then click "OK" button to save the settings.
4). Click the "Capture" button to start converting.
5). Click "Finish" button when you see the frame that you want to set as the last frame.
Diamond Member
Www.stainles...
.ecrater.com
Post Number: 20683
No.
Username: Wickedbass
Nashville, Tn
Post Number: 680
Username: Winniel
Armenia
:D
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Off Topic > How to convert swf to avi with iwisoft? [ « Previous ] [ Next » ]
