Home > Message Board > Off Topic > Archive through June 18, 2009 > Help
Author Thread: Help
Username: Susie0
Post Number: 8
Just started using ImToo Media Toolkit Ultimate.With one of it's components , ImToo DVD Creator (V3.0.39 build 1023), I am trying to burn a DVD from *.wmv files (which are supposedly "Supported Files"), a "Log" screen pops up and I get the following error, "The following files are failed to be added:" then it specifies the file path and name of that file.What am I doing incorrectly or what do I need to do to burn a DVD from a collection of *.wmv files?
Username: Easting
Post Number: 7
have you ever tried ImTOO HD Video Converter? It can convert HD videos to flv format of youtube video, and of course it will keep the high-def video quality for it can also output HD videos.You can download it at http://www.imtoo.com/hd-video-converter.html
Username: Eecom
No, no
imtoo dvd creator doesn't support .wmv to dvd.
you need to use a video converter, they also have it. imtoo video converter ultimate can do video conversion. you can google it or just go to their website for a download.
Home > Message Board > Off Topic > Archive through June 18, 2009 > Help [ « Previous ] [ Next » ]
