Thread: Router Help |
Gold Member Username: Loc_out
Team RE XXX
Post Number: 2845 Registered: Feb-05
| Posted on Friday, April 24, 2009 - 06:27 pm: |
Hey guys I'm going to be being a router soon. Will this be a good one? http://www.amazon.com/Skil-1820-2-Horsepower-Plunge-Router/dp/B0000C6DXZ/ref=sr_ 1_153?ie=UTF8&s=hi&qid=1240611248&sr=1-153 To make speaker rings isn't there a grid or something like that? |
Diamond Member Username: Wingmanalive
Www.stainles...
.ecrater.com
Post Number: 20300 Registered: Jun-06
| Posted on Friday, April 24, 2009 - 08:45 pm: |
Skil makes average entry level power tools. I'd put that router right next to Craftsman's lower end series routers. Will get the job done and are priced reasonable. Step up to Ryobi and Delta for a bigger price/performance. Next IMO is Makita and Dewalt. Another step up is Bosch and Porter Cable but they are pricey, and worth it. It mostly breaks down to your intended use. I don't recommend buying a $300 router if you're only going to pull it out once a month or two. I also don't recommend buying a no name special for $40 when all you'll get out of it is frustration. You want to match your use to your budget. Just as important as any power tool is the accessory/bit/blade you put on it also.
Platinum Member Username: Rovin
1 15 = 149.5 DBs ... Trinidad & T...
Post Number: 14893 Registered: Jul-05
| Posted on Saturday, April 25, 2009 - 12:14 am: |
agreed with pauly - though skill aint bad for the average home user i have a 2hp B&D that resembles the skill : looks like this actually http://www.amazon.com/s/qid=1240632163/ref=sr_nr_p_4_5?ie=UTF8&rs=228013&keyword s=Plunge%20Router&bbn=228013&rnid=339804011&rh=n%3A228013%2Cn%3A%21468240%2Ck%3A Plunge%20Router%2Cp%5F4%3ABlack%20%26%20Decker it works decent for its price range but next time i upgrade im getting like a tougher 3hp like either a makita , milwaukee , bosch like paul said it depends on how often u gonna use it & ur budget ... |
Gold Member Username: Th3pwn3r
I compensate...
Post Number: 9324 Registered: Jul-06
| Posted on Monday, April 27, 2009 - 01:48 pm: |
Haha, I clicked on this thread thinking of a router used for internet/networks. That's just my fault for assuming =/ |
Team RE XXX
Post Number: 2849 Registered: Feb-05
| Posted on Monday, April 27, 2009 - 08:03 pm: |
I hate going to shops and paying 15-20 but some speaker rings. I'm at a point were i want to have my own. I work at lowes so i get some discount. On the picture below that additional part on the router whats it called? I've search lowes but can never find it.
Ha ha ha Rob can you help me i can get online. |
Www.stainles...
.ecrater.com
Post Number: 20327 Registered: Jun-06
| Posted on Monday, April 27, 2009 - 09:24 pm: |
It's a circle cutting jig. Found all over the net. Google it. |
Team RE XXX
Post Number: 2850 Registered: Feb-05
| Posted on Tuesday, April 28, 2009 - 10:23 am: |
Thanks Paul. Will that part fit all router? |
Www.stainles...
.ecrater.com
Post Number: 20346 Registered: Jun-06
| Posted on Tuesday, April 28, 2009 - 05:18 pm: |
Most manufacturers will design their jig to fit most name brands. It only makes them more money if they do. Take a look at Partsexpress. Tad pricey but looks to work with most well named routers. http://www.parts-express.com/pe/showdetl.cfm?&Partnumber=365-270&utm_source=DIYA udio-Banner&utm_medium=Banner-Ad&utm_content=Router-Buddy-Circle-Jig-365-270&utm _campaign=DIYAudio |
Team RE XXX
Post Number: 2852 Registered: Feb-05
| Posted on Wednesday, April 29, 2009 - 05:31 pm: |
thanks paul you been a great help. |
