Thread: How to convert .TOD to avi, mp4, wmv, flv, mov, swf, mpg and other video formats? |
New member Username: Anna66
Post Number: 2 Registered: Mar-09
| Posted on Wednesday, April 08, 2009 - 12:06 am: |
You just bought a brand new camcorder, let¡¯s say, JVC GZ-HD7, or other ones likewise that the extension file format is TOD. I am pretty sure they have brought you a lot fun as a family used digital product, many great valuable moments like wedding, family get-together, celebration parties, opening ceremony and many other interesting things just recorded in there¡as for professional use, it is simply a must in their work, some even made their name by living on it. Whether to the new users or to the Pros who have possessed for a long time, they all find a same problem with the TOD format. The problem is to find software programs that support the .TOD file that it uses. Many ways have been brought up and tried; some had tried to spend time on the phone with a tech support rep at JVC, some just tried the complicated and expensive Adobe Premier. What a suffering! Don't fret folks; your camcorder is well worth it.iOrgSoft TOD converter takes all your troubles and worries away promptly. It enables you to convert .TOD video format to many other popular ones like avi, mp4, wmv, flv, mov, mkv, 3gp, 3g2, dv, mpg, rm, rmvb, swf. So that you can enjoy your converted TOD video on PC with various media player, or you can just enjoy them on your portable devices like blackberry, PSP, Gphone, iPod, Creative Zen, etc. I have to say TOD converter is quite simple yet very powerful; the conversion can be done with just few mouse clicks. TOD converter is never something that is mystery. Just following the Tutorial below to learn How to convert .TOD to avi, mp4, wmv, flv, mov, mkv , 3gp and other formats? Tutorial Step by step on How to convert .TOD to avi, mp4, wmv, flv, mov, swf, mpg and other formats? Step1 Turn on your pc. Download and install TOD converter Click here to download and install it by running iOrgsoft TOD converter.exe Step 2: Turn on your camcorder and connect it to pc. Transfer the .TOD file onto PC. Run TOD converter; select the .TOD file you want to convert by clicking the Add or File button to load TOD info. Click the profile button to define the output video format. Step 3: click the Edit button to set detailed info for the desired video. A. Click the Trim button to set the length/range of the video that need to be converted. You can choose a part of a TOD or the whole one to convert B. Click the Effect button to tune the saturation, contrast, brightness values and make sure are the one you preferred, preview the change on the screen. C. Click the Crop button to cut the unnecessary part or black part of the movie. Step 4: Convert video After all settings is done. You are ready to start conversion. This step will take you a while to carry out the conversion process, the time vary with different parameters you set. You want to watch the converted video on your portable devices? Fine, you need a USB cable to transfer the converted video. Just drag and put¡done. iorgsoft Tod-Converter |
