Home > Message Board > Off Topic > Archive through June 18, 2009 > External Hard Drive Suggestions
Author Thread: External Hard Drive Suggestions
Username: Rideredder
Cornell, IL
Post Number: 1582
I'm looking for a portable external hard drive. My budget is about $100.
What do you guys think about this one..
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136321
I really don't need 1 TB of space, but for the price and all the positive reviews I think I'm going to get it.
Diamond Member
Www.stainles...
.ecrater.com
Post Number: 20197
When you say you really don't need 1 TB of space you really do. Trust me! Space is getting cheaper every day and I can remember paying $100 not 4 months ago for only a 500gig (maxtor) external. To get 1 TB for that is good/great.....today. Depends on how much you need that much space NOW.
It's only going to get cheaper and cheaper.
Username: Rovin
1 15 = 149.5 DBs ...
Trinidad & T...
Post Number: 14832
when 160 internal drives was the biggest thing i got some WD & they kept crashing so from since then i never liked the brand ...dont know if they improved their technology & dont have that problem again
i have always used seagate barracuda which r pretty good .....
Username: Nd4spd18
Philadelphia, PA
Post Number: 10294
WD is the worst maker of hard drives out there. Been that way since the 90s or as long as I can remember. They are known for extremely high failure rates.
Seagate is the opposite, lowest failure rate in the business. I have yet to replace one.
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 3592
Ive always had Fathom Drives, never had one fail. Im using the 1TB right now and dont have a single complaint.
Home > Message Board > Off Topic > Archive through June 18, 2009 > External Hard Drive Suggestions [ « Previous ] [ Next » ]
