Thread: Oh Chad Lee, One more Time |
Gold Member Username: Kpa2727
Old Bridge,
NJ
USA !
Post Number: 1132 Registered: May-07
| Posted on Tuesday, April 22, 2008 - 07:10 pm: |
one more time man, heres how u get photoshop cs 3 extended. download adobe cs3 extended trial from adobe. then download this, its a key gen, try to activate, with it. it WILL fail,so now select activate by phone,photoshop will give you a code, enter that in the key gen, now the key gen will give you another code, enter that and your done. http://download.yousendit.com/C3ABA0512B36BA15 |
Relevant Product Info
Diamond Member Username: Bestmankind
Los Angeles,
CA
Post Number: 20467 Registered: Oct-05
| Posted on Tuesday, April 22, 2008 - 07:17 pm: |
thanks man. ima try that. thanks again. |
Old Bridge,
NJ
USA !
Post Number: 1135 Registered: May-07
| Posted on Tuesday, April 22, 2008 - 07:32 pm: |
no problem , i figure it be easier this way for you. |
