Home > Message Board > Off Topic > Adobe Photoshop
Author Thread: Adobe Photoshop
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2437
I was wondering if anyone had a good place to download Photoshop. I used it a couple years ago and I think it would be fun to get into again. If anyone has that, I would greatly appreciate it. Thanks!
BTW...I don't really care what version it is. Just whatever someone can suggest.
Relevant Product Info
Username: Kpa2727
Old Bridge, NJ
USA !
Post Number: 1124
download cs extended trial from adobe, i'll load u up with a keygen.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2438
Alright, I just downloaded the Adobe Photoshop CS3 Extended
What now Keith?
Username: Livin_loud
COD4 Addict ...
Level 2 pre...
Post Number: 2414
you familiar with torrents BCS?
Username: Kpa2727
Old Bridge, NJ
USA !
Post Number: 1131
forget torrents they will get u in trouble, download this, its a key gen, try to activate, with it. it WILL fail,so now select activate by phone,photoshop will give you a code, enter that in the key gen, now the key gen will give you another code, enter that and your done.
http://download.yousendit.com/C3ABA0512B36BA15
Username: Kpa2727
Old Bridge, NJ
USA !
Post Number: 1133
btw sorry BCS ur post never showed till now.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2439
Well, I have been downloading the Adobe Photoshop CS3 Extended all day and it is still only half done. I have very fast internet and a new computer too :-( So after I download this from Adobe's site, then I do your last instructions?
Username: Project6
Post Number: 15804
Don't keygens usually end up getting deleted by your anti-virus software? Aren't most of those things trojans?
Username: Kpa2727
Old Bridge, NJ
USA !
Post Number: 1142
berny i scanned this and i used this for about a year and a half plus its been on my hardrive for all of that time, THE KEY GEN IS CLEAN ! and how that happens is when a keygen contains a worm. older keygens when ran infected your system dropping a worm into the system hence why virus softwares went ape shittt otherwise berny NO virus software will not delete key gens. BUT patchers do get delted alot and infect alot more then keygens do, all a keygen does is give you a random genreated code based on a serial nothing else it dosen't touch any files. now the reason this works so well is because the telephone support uses the same method to activate. to BCS sorry to hear bud, it should not take more then 20 min on a slow day. adobe has gone down a few times so they might be haveing server trouble. they hosted some new photoshop for facebook and others thats a beta, ever since thier server had been crashing on and off so u could of got caught up in that. also yes after downloaded follow the steps i wrote.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2441
Thanks a lot man, I appreciate it. I finally got everything to work right.
Username: Project6
Post Number: 15809
Good info man, thanks
Username: Thumpinwith8s
2 RE8s,PG Xenon 400.1, 135.5dbs!!!!
Post Number: 1104
Fyi ...pops up with windows defender as a trojan....so somebody lied
Username: Kpa2727
Old Bridge, NJ
USA !
Post Number: 1145
wolf defender is touchy on all files and isn't right. u run any p2p program or even yahoo. defender missdetects it as a trojan.yahoo even went as far to post a article about defender.
Username: The_image_dynamic
San Diego, California
Post Number: 3888
I probably have more scanners than anyone here and I can guarantee you that file is 100% clean.
Username: Somedonniedude
Illinois
United States
Post Number: 1487
Keith, what do you mean torrents will get you in trouble?
Username: Project6
Post Number: 15817
So, how do you download it without being purged by the AV?
Username: Kpa2727
Old Bridge, NJ
USA !
Post Number: 1147
thanks brad, berny normally if the keygen is seen as bad by virus software you can just let the virus program make an exception. also to donnie, it depends on the bandwith used if you start out of nowhere sucking down up to 4 gigs of banwidth from downloading, your provider will get suspicious and investigate. if your doing movies illegal ones not x rated, they will catch u i got caught once in 04 and warned personally by certified letter from mgm's head offices if i don't stop a 500 grand fine will be mine. so that's how torrents can get you in trouble, certain programs are tagged as a setup. u download them and a companies watching then they sue you. if you use a proxy server and mask your ip address you can probably get away with murder. but it's still a risky thing, slip once and your in court up to your azz in debt. i run xbox live alot so my average bandwith use can average a gig to 4 gigs depending on demo downloads. so it's pretty easy to slip a movie in here and there if i wanted to. the other thing that net providers do to is "cap" you, a cap limits your speed and bandwith. that way you can't download a million movies in no time.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Off Topic > Adobe Photoshop [ « Previous ] [ Next » ]
