Home > Message Board > Off Topic > Archive through January 31, 2008 > Downloaded halo
Author Thread: Downloaded halo
IM THE REAL SLIM SHADY
Post Number: 16822
i downloaded halo the other day. i am trying to install it but i can't.
this is the instruction that came with it. can someone make some sense out of this for me?
" Halo: Combat Evolved mini image
1.Mount the "Halo-MINI.mds" with Daemon Tools or Alcohol 120%.
2.Launch and play the game.
-an average user
14.01.2007"
Username: Livin_loud
Do Work
Fi Audio
Post Number: 2154
i use daemon tools. if you install daemon, after your restart your comp, a red icon should be in the clock panel. right click it and "mount" the halo mds file. should launch immediately.
Username: •cam•
BC
Post Number: 1639
You need the real thing to play. The mini image will allow you to play, but you need the reg. #. At least to play online.
Post Number: 16825
i got it now.
cam i just want to play the single player.
Username: Rideredder
Cornell, IL
Post Number: 1305
How big was the file you downloaded Chad? I'm downloading it now, but the file is only 610MB. Is that going to be the full game, or just the demo?
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 13584
I have the original Halo for PC CD..I will send it to you if you want...
Username: The_image_dynamic
San Diego
Post Number: 3351
That's the whole game. Depending on file compression used it will range from 600-1000 megs. It was from 2003 and before the 4+ gig games surfaced.
Post Number: 16831
thanks guys. i just downloaded another one and that one work like a charm.
Home > Message Board > Off Topic > Archive through January 31, 2008 > Downloaded halo [ « Previous ] [ Next » ]
