Home > Message Board > Off Topic > Archive through January 31, 2008 > Hard Wiring a Radar Detector
Author Thread: Hard Wiring a Radar Detector
Username: Gavbo211
JL Audio 10w3v2, IL
US
Post Number: 768
Are there any advantages/disadvantages to hard wiring a radar detector? i'm tired of having the cigarette lighter cord always in my view.. because of the way my dash is it just looks bad. i'm just wondering if i buy a hard wire kit am i going to lose and power or anything like that? anyone with any experience, your opinion is appriciated.
also, my radar is an Escort 8500 X50 if that makes any difference.
This was the kit i was looking at:
http://cgi.ebay.com/Escort-Direct-Hard-Wire-Cord-Kit-8500-x50-Solo-S2-7500_W0QQi temZ120205442790QQihZ002QQcategoryZ39767QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Gavbo211
JL Audio 10w3v2, IL
US
Post Number: 769
ttt.. somebody has to know.
Username: Nd4spd18
Northwest PA
Post Number: 5311
You can hard wire any 12 volt component. That kit would work great but you could also just get 2 tap-in connectors, cut the end off the cigarette lighter cord, and tap in to the wires behind the dash.
Username: Project6
Post Number: 14252
The only disadvantage I could think of is losing the convenience of being able to move the detector from one car to another.
Username: Skibum12189
Cleveland
Post Number: 2404
i have mine hardwired ill take pictures later, its really easy
Username: Gavbo211
JL Audio 10w3v2, IL
US
Post Number: 770
nice.. that's what i wanted to hear. thanks for the help guys.
and cal, pictures would be great. as for moving it.. i don't think that's a very big concern of mine. last time i let my friend "borrow" mine it ended up gone for 4 months so.. lol.
Username: Shortysetnies
Rock Vegas, NC
US
Post Number: 1665
Yeah, cut the adaptor off, strip the wires, find your 12v on the back of the dash or in the fuse panel that is on when the car is and tap into it and ground the other wire. Pretty simple and look MUCH cleaner IMO
Home > Message Board > Off Topic > Archive through January 31, 2008 > Hard Wiring a Radar Detector [ « Previous ] [ Next » ]
