Thread: Cotton filler in SUB BOX?? |
Bronze Member Username: Alpine97
Greenwood,
Indiana
Post Number: 54 Registered: Jan-08
| Posted on Wednesday, January 09, 2008 - 04:50 pm: |
I heard if you fill the inside of the box with cotton or whatever, it makes the SQ go up. I think whoever thought of that was stupid, but, I guess I wouldn't know bc I have never done that. Is it true though, are there any secrets to enhance SQ or make sh!t louder>? Also, I heard if you mount an amp to the box it can draw current from the magnets and cause the amp to over heat. I would also think that would be bad because of the vibes the box would give to the amp couldn't be good for its internals... |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 5269 Registered: Jul-06
| Posted on Wednesday, January 09, 2008 - 05:08 pm: |
Holy hell you need to stop listening to whoever you you that stuff, right now haha. None of that is true. Ployfill in a sealed box makes the box seem slightly larger than it actually is, that's all. |
Greenwood,
Indiana
Post Number: 58 Registered: Jan-08
| Posted on Wednesday, January 09, 2008 - 05:20 pm: |
Polyfill...that what it was..I never listened to him, I just heard what he said and was asking if it was true...the sad thing is that he works at an audio shop here in nap..lol |
Gold Member Username: Insearchofbass
Post Number: 7500 Registered: Jun-04
| Posted on Wednesday, January 09, 2008 - 05:26 pm: |
This is true..polyfill can help sq and you can use fill in a ported box as well but you need to buy it in mat form |
Post Number: 7501 Registered: Jun-04
| Posted on Wednesday, January 09, 2008 - 05:29 pm: |
ported....and glue or staple it onto the walls of the box |
Northwest PA
Post Number: 5275 Registered: Jul-06
| Posted on Wednesday, January 09, 2008 - 05:32 pm: |
I'm gonna have to call BS on that one. How could it when all it does is artificially affect the box volume. It doesn't change the sub........ |
Post Number: 7503 Registered: Jun-04
| Posted on Wednesday, January 09, 2008 - 06:04 pm: |
well its also said to break up standing waves M.S. |
Bronze Member Username: Davidt487
Texas
Post Number: 74 Registered: Dec-07
| Posted on Wednesday, January 09, 2008 - 06:20 pm: |
i can say its true. i put some in my sealed box my type r is in and it made it not as boomy the box is a lil on the small side so... im a believer |
Gold Member Username: Adddisorder
Palm Beach,
Florida
Post Number: 5727 Registered: Jan-06
| Posted on Wednesday, January 09, 2008 - 06:25 pm: |
yes polyfill will absorb standing waves and will make a difference, to those who know what to listen for. |
Platinum Member Username: Bestmankind
IM THE REAL SLIM SHADY
Post Number: 16735 Registered: Oct-05
| Posted on Wednesday, January 09, 2008 - 06:33 pm: |
that is if you like that kinda sound. i personally don't like it with polyfill. |
Platinum Member Username: Rovin
4 10 Pioneer...
Post Number: 12728 Registered: Jul-05
| Posted on Wednesday, January 09, 2008 - 09:45 pm: |
if u make a proper box there is no real need for polyfill ..... |
Gold Member Username: •cam•
BC
Post Number: 1610 Registered: Nov-06
| Posted on Wednesday, January 09, 2008 - 09:51 pm: |
...unless you need the extra space in a small sealed application. Also, most of us don't possess the software/knowledge of acoustics to build a box that is properly tailored to a vehicle, so polyfill is good for making small adjustments to get the most out of it that you can. Had you built it for your specific car, you might not have to play around with it, but since it will end up having far different characteristics than WinISD or w/e models, polyfill can be handy. |
Platinum Member Username: Wingmanalive
A pic is worth
1000 posts!!
Post Number: 12310 Registered: Jun-06
| Posted on Wednesday, January 09, 2008 - 10:47 pm: |
Just my two pennies but some high end home audio speaker boxes come with poly already attached. Why would a designed speaker enclosure have poly in it? Just throwing it out there fellas...... |
