Home > Message Board > Off Topic > Archive through January 31, 2008 > OT- can some1 post a link to the EXAC...
Author Thread: OT- can some1 post a link to the EXACT items needed to hook up these fans and neons?
Username: Mj23dynasty
Some where 12 wangin o..., The Mighty J...
Post Number: 940
I'm running two small fans cpu fans I guess and a string of EL wire from street glow neon light what would be the exact relay,switches and wires I would need to get these working I need links. I tried to figure it out myself but idk what I'm looking out. Thanx in advance guys.
IM THE REAL SLIM SHADY
Post Number: 16577
try here.
www.bcae1.com
Post Number: 941
I was already reading on there chad I need links to exact items I need to buy.
Post Number: 16578
what do you want to buy? a relay? if so you can get that at radio shack.
Post Number: 16579
http://www.radioshack.com/product/index.jsp?productId=2062477&cp=&sr=1&origkw=relay&kw=relay&parentPage=search
Post Number: 942
Idk chad thts what I'm askin what all do I need 2 make it work and links to the items I need I was told I need a relay,switches, and wiring obviously but idk which kind of what if u kno what I'm saying. I read bcae and it basically explains what a relay does it doesn't tell me which kind to get and where and all the other things I need. And I have no clue what I need to make the el wire work
Post Number: 16582
oh its to power your fans. that relay will work. you can just connect it on the remote on your head unit.
Post Number: 16583
Post Number: 943
Well if I'm running it on a switch do I just connect the wire to the switch instead of the remote turn on wire???
And what about the el wire from st glow I think I have to buy a 12v power souce for tht
Post Number: 16585
oh you want the fan connected to a switch? then just find a good 12v source and connect it with a switch. i thought you want the fan to run constantly when your amps are on.
Post Number: 16586
oh and btw, i don't know why you even want to run a fan. i think you are just wasting time by doing that.
Post Number: 944
Well I already bought it and installed it so nothing lost its a learning experience
Post Number: 16589
tru dat.
so how do you want to run it? you want it to be on constantly on when your amp is on or do you want to be able to decide when you want it on?
Post Number: 945
I wana control em myself via a switch
Home > Message Board > Off Topic > Archive through January 31, 2008 > OT- can some1 post a link to the EXAC... [ « Previous ] [ Next » ]
