Thread: WTF - Need computer help |
Gold Member Username: Livin_loud
Do Work
Fi Audio
Post Number: 2086 Registered: Jan-06
| Posted on Wednesday, December 19, 2007 - 11:03 pm: |
ok i consider myself pretty suave when it comes to using computers but this one is stumping me. windows (xp mce) itself lags out every so often, for no reason. everything just freezes, and ~15 sec later its fine, and repeats. i eliminated all the process's i could and it still does it. anybody know wtf is goin on? |
Gold Member Username: The_image_dynamic
San Diego
Post Number: 3217 Registered: Dec-06
| Posted on Wednesday, December 19, 2007 - 11:13 pm: |
Download hijackthis, run "do a system scan and save a logfile". Post logfile here and I will take a look. Probably spyware, a couple BHO's and/or worm/virus. http://www.merijn.org/files/HiJackThis_v2.exe |
Do Work
Fi Audio
Post Number: 2087 Registered: Jan-06
| Posted on Wednesday, December 19, 2007 - 11:36 pm: |
fileden.com/files/2007/2/24/813795/hijackthis.log dont think its a virus of any type, i run bitdefender total 08. i used to have ad-aware and it helped out a bit. gonna get that again and see what it says... |
San Diego
Post Number: 3218 Registered: Dec-06
| Posted on Wednesday, December 19, 2007 - 11:51 pm: |
You have far to many HKLM\..\Run items. Go into msconfig and stop all those from starting up. Also get rid of the Bit Comet BHO. Stop the NMIndexingService.exe from running also. You also have a ton of running processes that are suspect. Your hijackthislog should be 1/3 the size it is. Do some cleaning up and don't run anything that your comp doesnt need at startup. Start programs when you need them only. Ace IE and get Opera. But what is causing your freezing is almost for sure Bit Defender. Uninstall it, clean up all of the registry keys left behind using JV16, get another antivirus and see if that fixes the problem. |
Gold Member Username: Tatonka
-[Team Audib...
Post Number: 1158 Registered: Mar-07
| Posted on Thursday, December 20, 2007 - 12:04 am: |
Bit Defender = trash. I took a look at the log and I agree with Brad completely. It is way to big and has allot of unnecessary things running. If all else fails: format c: |
Do Work
Fi Audio
Post Number: 2089 Registered: Jan-06
| Posted on Thursday, December 20, 2007 - 12:05 am: |
AA just brought up a bunch of cookies and a few mru's... thanks for the help though Brad, i'll let you know the results when i'm done overhauling |
Gold Member Username: Carguy
Post Number: 6838 Registered: Nov-04
| Posted on Thursday, December 20, 2007 - 12:15 am: |
More reasons why I hate $hittySoft products. If it still lags, try the defrag and turn off the "fast search/indexing" option for the hard drive. It's a waste of hard drive space and resources. After it's turned off, you'll notice that your HD is no longer that busy. |
-[Team Audib...
Post Number: 1160 Registered: Mar-07
| Posted on Thursday, December 20, 2007 - 12:32 am: |
"More reasons why I hate $hittySoft products." You are probably using Windows right now Isaac lol. What is there to hate about Windows? If you know what you are doing, you won't have any problems at all. |
Do Work
Fi Audio
Post Number: 2090 Registered: Jan-06
| Posted on Thursday, December 20, 2007 - 12:33 am: |
recommended AV? |
-[Team Audib...
Post Number: 1161 Registered: Mar-07
| Posted on Thursday, December 20, 2007 - 12:35 am: |
Nod32. IMO, best A/V and spyware scanner out. |
Silver Member Username: Shade
Moxee,
Wa
U.S.
Post Number: 521 Registered: Nov-06
| Posted on Thursday, December 20, 2007 - 12:37 am: |
lags out like as in it just freezes? nothing opens? and then it all let's up a min. later? http://codecavalier.com/blackviper/WinXP/servicecfg.htm read that page and follow what he says, choose "power user". if after that, u still have the prolbem try taking out a stick of ram and turning ur pc on and seeing if u get the same results, if so, take out the other stick of ram and put the other one back in. repeat. |
Post Number: 6843 Registered: Nov-04
| Posted on Thursday, December 20, 2007 - 12:41 am: |
Nick V, I do know what I'm doing, but it's annoying to use a product that was badly designed and charged high fee. Try installing a fresh copy of XP in a new computer without any PATCHES. See how fast it boots up. Now apply all the patches needed. Now time it. Install another annoying product Norton, then time it again. Now let the $hittySoft turn on indexing on your hard drive and see how slow it runs. Throw in 4 cpu processor and see what happens. The OS only sees 2. $hittysoft then tells you to fork over more money for a 64bit OS with more flaws and patches. Do you get the picture? I'm currently running Windows inside a Mac. It is so much better than a true Windows machine. FYI, Mac is 64bit and doesn't ask for more money for it, costs less than half the price of Windows. Did I mention it doesn't crash? |
Do Work
Fi Audio
Post Number: 2091 Registered: Jan-06
| Posted on Thursday, December 20, 2007 - 12:51 am: |
ok, so far i've disabled a bunch of hklm's, startup items, and stopped 1 or 2 services. things were kind of faster, but then i noticed a process that wasn't there before called "upnp.exe", which is associated with bitcomet. i ended that process and things are back to normal jeremy, it would go fine for like 30 sec or so, then all programs would lag, and then run fine again. btw, i can't open my case w/o voiding warranty i'll continue to tweak some other stuff anyways just to be safe. thanks for the help guys |
-[Team Audib...
Post Number: 1163 Registered: Mar-07
| Posted on Thursday, December 20, 2007 - 07:58 pm: |
Try installing a fresh copy of XP in a new computer without any PATCHES. See how fast it boots up. Now apply all the patches needed. Now time it. Install another annoying product Norton, then time it again. Now let the $hittySoft turn on indexing on your hard drive and see how slow it runs. Throw in 4 cpu processor and see what happens. The OS only sees 2. $hittysoft then tells you to fork over more money for a 64bit OS with more flaws and patches. Do you get the picture? I'm currently running Windows inside a Mac. It is so much better than a true Windows machine. FYI, Mac is 64bit and doesn't ask for more money for it, costs less than half the price of Windows. Did I mention it doesn't crash? 1. I never install any microsoft patches on my windows machines, and they all run flawlessly for many different tasks. 2. Norton blows anyway, don't associate it with windows. Try a real anti virus. 3. I have indexing turned on for my hard drives and it runs smooth as it did when it was off. 4. You should know that the 32bit windows xp will see all 4 processors. So I don't know where you get 2 from? 5. If you're windows crashes, its a user error that you created yourself, Windows doesn't just crash if you have a clue about what you are doing. 6. The majority of programs/games are in fact 32bit windows compatible. If you start running a 64bit OS, then you won't have as much of a broad selection of software. |
Do Work
Fi Audio
Post Number: 2095 Registered: Jan-06
| Posted on Thursday, December 20, 2007 - 08:28 pm: |
so everything decided to take a fat sh!t on me again. formatting will be done shortly but i have a dillema... kind of. i have a LOT of media. can i partition a spot in my hd to put it all in that wont be formatted? |
Moxee,
Wa
U.S.
Post Number: 523 Registered: Nov-06
| Posted on Thursday, December 20, 2007 - 09:43 pm: |
burn it to disc? |
Do Work
Fi Audio
Post Number: 2096 Registered: Jan-06
| Posted on Thursday, December 20, 2007 - 10:21 pm: |
i'm talkin over 40gb haha and i don't have an DL dvd's or blu-ray capability. i have an external hd but it takes mad long to transfer that much and i just don't wanna go through it all |
Moxee,
Wa
U.S.
Post Number: 525 Registered: Nov-06
| Posted on Thursday, December 20, 2007 - 11:28 pm: |
perhaps u sould winzip it or winrar it to a lower my tolerable size .... |
Do Work
Fi Audio
Post Number: 2104 Registered: Jan-06
| Posted on Thursday, December 20, 2007 - 11:41 pm: |
zipping that much data takes even longer than to just transfer it all lol |
-[Team Audib...
Post Number: 1164 Registered: Mar-07
| Posted on Thursday, December 20, 2007 - 11:47 pm: |
Eric don't be lazy lol. Just let it transfer to your external over night. OR: Take the HDD out of your external, then hook it up as a slave on your computer. Might be a little bit faster to transfer that way. |
Do Work
Fi Audio
Post Number: 2127 Registered: Jan-06
| Posted on Monday, January 07, 2008 - 03:09 am: |
windows updates anyone?  |
