Home > Message Board > Suggestions & Feedback > Archive through December 29, 2006 > Phono/Turntables
Author Thread: Phono/Turntables
Username: Imp88
Dear Readers,
I have in my possession a Sansui Model 370V. There is a hum using the Sansui Model 370V. The wires were connected as follows:
1. Red and Green were connected to the Centre and outer RCA Cable or cable with a screen over the centre cable.
2. Blue and White were connected to the Centre and outer RCA Cable or cable with a screen over the centre cable.
The cable is about a 1.5 metre long connected to the Equaliser Phono input (with a variable volume output). Was there any thing that I did wrong that causes the hum.
Thanks for the help, readers
Relevant Product Info
Username: Project6
Post Number: 11748
Wrong forum, Cheng.
Next time go to the Home Audio" Forum, there is a section there that states "Phono"
http://forum.ecoustics.com/bbs/messages/1/21.html
But it seems like your problem is a ground wire. You need to connect that to the chassis of your input device.
Home > Message Board > Suggestions & Feedback > Archive through December 29, 2006 > Phono/Turntables [ « Previous ] [ Next » ]
