Home > Message Board > Suggestions & Feedback > Archive through August 09, 2005 > Not compatable with Opera
Author Thread: Not compatable with Opera
Username: Videobruce
Buffalo , NY
Post Number: 39
When I post a message sometimes I loose all formatting. New paragraphs and blank lines are lost.
I validated the site and it returns errors. See for yourself;http://validator.w3.org/
http://www.htmlhelp.com/tools/validator/
Relevant Product Info
Buffalo , NY
Post Number: 41
For some unknown reason it worked this time(the first).
I don't know what's going on. I had two posts that didn't retain the spaceing, now all of a sudden they do.
2nd issue, why do I have to keep loging in all the time? I have never been to a forumn that this had to be done. Once your 'in' your 'in'!
If I log into 'my profile', close it I have to log in again.
If I post with my username and password and post again in another thread, I have to use my username and password again.
Yes, I do have cookies enabled.
Moderator
Username: Admin
Post Number: 404
Please login and check your profile:
http://forum.ecoustics.com/cgi-bin/bbs/board-profile.pl
There should be a checkbox in the box, "Remember my username and password in a cookie".
With this option enabled it will automatically fill in the username & password boxes.
Buffalo , NY
Post Number: 51
It has been!
Have you tested this with Opera?
Buffalo , NY
Post Number: 52
How do you stop monitoring a single thread?
Moderator
Username: Admin
Post Number: 406
Within your profile, uncheck the "e-mail notifications" boxes.
What version of Opera are you using?
Buffalo , NY
Post Number: 54
If I uncheck that, then ALL the subscription will be canceled, corect?
V8
Home > Message Board > Suggestions & Feedback > Archive through August 09, 2005 > Not compatable with Opera [ « Previous ] [ Next » ]
