Thread: To: Admin - Problems logging in... |
Silver Member Username: Ojophile
ON
Post Number: 156 Registered: Jun-04
| Posted on Monday, November 29, 2004 - 10:04 am: |
To admin: Since last weekend Nov. 27), I've been having problems logging in. I sign on with my usual user name/ID and password, but I don't see the notification, "logged in as ..." Neither do I see my user name and pwd (****) in the post-message box. Anyone have the same problem? This is happening on any PC that I use. See below. I'm already logged in but I don't see my user name. I have to type it again in order to post this message.
Please advise and/or correct the situation. Thanks, Don
Relevant Product Info
Moderator Username: Admin
Post Number: 171 Registered: Dec-03
| Posted on Monday, November 29, 2004 - 04:58 pm: |
We are currently investigating your login problems |
Post Number: 174 Registered: Dec-03
| Posted on Tuesday, November 30, 2004 - 06:09 pm: |
There are two components to having a member's username and password filled into the form. Cookies and Javascript must both be enabled in the browser, so that the information is filled in. Some pop-up blockers or a filtering proxy might also be a cause of the problem. Entering in the correct username/password manually in the boxes when posting will always get your posts added. |
ON
Post Number: 172 Registered: Jun-04
| Posted on Friday, December 03, 2004 - 10:50 pm: |
To Admin: Thanks, but I still can't log in and stay logged-in. I've enabled all Cookies including 3rd party ck.. JavaScript has always been enabled. On another forum that I'm a member of, I'm able to log in and remain so until I exit my browser. Please re-investigate and advise. As I said, the problem exists regardless of the PC that I use. Thanks, Don
Post Number: 175 Registered: Dec-03
| Posted on Monday, December 06, 2004 - 02:48 am: |
Try clearing the cookies in your browser. Also make sure that your user profile, has the box checked: "Remember my username and password in a cookie." http://forum.ecoustics.com/cgi-bin/bbs/board-profile.pl
ON
Post Number: 175 Registered: Jun-04
| Posted on Monday, December 06, 2004 - 09:55 pm: |
To: Admin I must have unchecked that box somehow while reviewing my recent posts. It works now. Thanks a lot! Don
Silver Member Username: Eskimo3
Post Number: 117 Registered: Dec-04
| Posted on Saturday, January 08, 2005 - 10:09 am: |
How do you do that again,I'm having the same problem.I know I can just look up there but I don't want to have to look through all those other posts.Admin,help!!!!!!!!!!!!!!!! |
Post Number: 130 Registered: Dec-04
| Posted on Thursday, January 13, 2005 - 08:51 am: |
Hey Admin??????? You in there? |
Post Number: 205 Registered: Dec-03
| Posted on Thursday, January 13, 2005 - 06:34 pm: |
Make sure that your user profile, has the box checked: "Remember my username and password in a cookie." http://forum.ecoustics.com/cgi-bin/bbs/board-profile.pl Cookies and Javascript must be enabled. |
Post Number: 140 Registered: Dec-04
| Posted on Monday, January 17, 2005 - 11:23 am: |
I had no idea what the cookie was so I didn't check it, can I change it?If so, how? |
Post Number: 207 Registered: Dec-03
| Posted on Monday, January 17, 2005 - 01:23 pm: |
A cookie is a small file which is created on your computer when you login that remembers your login information. Most web browswers (e.g. Internet Explorer) will automatically accept cookies. You can manually disable the feature within your browser. As long as it's enabled you shouldn't have to check anything. |
Post Number: 154 Registered: Dec-04
| Posted on Wednesday, January 19, 2005 - 05:17 pm: |
Can I change it and if so, how? |
Post Number: 209 Registered: Dec-03
| Posted on Thursday, January 20, 2005 - 12:07 am: |
We have enabled it for you in your profile. You can edit your profile at this link: http://forum.ecoustics.com/cgi-bin/bbs/board-profile.pl
Post Number: 170 Registered: Dec-04
| Posted on Sunday, January 23, 2005 - 09:09 am: |
Thanks but I'm still not logging in, and what do the little trash cans next to my posts mean? |
Post Number: 206 Registered: Dec-04
| Posted on Wednesday, January 26, 2005 - 08:22 am: |
Oh, my mistake it's working now, thanks!  |
