Home > Message Board > Home Video > TV Basics > Archive through January 22, 2004 > Zenith HDTV and 720p
Author Thread: Zenith HDTV and 720p
mikewood
DOes anybody know what the Zenith HDTV model No. C32V37 does with a 720 prog. signal? I know it doesn't dislpay it in that format, but does the set down or upconvert the signal? I really like the look of the unit and am curious as to it's quality.
If any of you actually has the set I would like to hear your opinions of its performance as well.
Thanks.
mikewood
Don't worry about it, wait for the 1080p models to come out.
TheBobGoat
1080P ?? i heard that may or may not ever come out
1080i and 720p have similar qualities.
its like all technology, if you want it, buy it and you know it will go out of date eventually, but by then..just buy the new one again -- nature of the business.
but if you wait for 1080p then you may be waiting too long
Home > Message Board > Home Video > TV Basics > Archive through January 22, 2004 > Zenith HDTV and 720p [ « Previous ] [ Next » ]
