Thread: Multiple Satellites On Same Dish |
Very Thankful Unregistered guest |
| Posted on Friday, September 17, 2004 - 09:25 pm: |
I have a Directv RCA dish. Can I get a dual LNB and a disq switch to receive 110 and 119 using the same dish and 1 coax down to the FTA receiver? Thanks for any help that can be provided.
| Posted on Friday, September 17, 2004 - 10:20 pm: |
No ur gonna have to buy a new dish with dual lnb.s if u want both sats or put up another dave dish. heard of one guy who taped another lnb to the dave dish and says it works ok |
| Posted on Friday, September 17, 2004 - 11:04 pm: |
Thanks for the info. So, what type of dish should I buy and can I use a disq switch to maintain only 1 coax to the receiver? |
| Posted on Friday, September 17, 2004 - 11:27 pm: |
I saw a DiSEqC 1.2 MOTORIZED H-H Mount on ebay. Can I hook this up to receive 3 satellites using the dave dish? |
| Posted on Saturday, September 18, 2004 - 12:48 am: |
VT buy a dish that has a dual LNB, use a 4 port disq switch, use your direct dish for bev and the dual dish for charlie,and yes u can maintain one line to the ird, but u have to get 3 pcs. of cable about 6 ft between lnbs. and switch...if u use a hh mount how u gonna change the az....there are alot of dual lnb dishes that will work but avoid the ones with a switch built in... |
| Posted on Saturday, September 18, 2004 - 03:27 am: |
Anonymous, perfect. so, the dual dish I buy - is there a specific make I should look for? I always thought dual lnb meant you could connect to 2 receivers but this sounds like 2 satellites to 1 receiver off 1 dish (i hope)... Very Thankful |
squirrel Unregistered guest |
| Posted on Saturday, September 18, 2004 - 09:05 am: |
Get Oval DTV dish (not round) with 2 lnb's and align the 119 and 110 satellite for Dishnetwork and round single DTV dish for Bev. |
| Posted on Saturday, September 18, 2004 - 10:30 am: |
i use a direct tv dish for dishnetwork.. i align one lnb for 119...then I velcro and tape another lnb for 110.. works fine for me. |
| Posted on Saturday, September 18, 2004 - 11:57 am: |
VT there's a twin lnb which is what u were refering to and then there's a dual for two seperate sats.check out this site their legit, but can't u buy a dish locally, u live in T>O there's lot's of places or check out the buy an sell newspaper or website...later |
| Posted on Saturday, September 18, 2004 - 11:59 am: |
VT sorry forgot to give website incredibledss.ca just a bit hung over...later |
LeafsRule Unregistered guest |
| Posted on Saturday, September 18, 2004 - 01:35 pm: |
I have my Pansat 2500A receiver hooked up to my DirectTV dish.It's aimed at Expressvu sattelite but I get a lot of bad or scrambled channels, what could be the problem? Thanks |
| Posted on Saturday, September 18, 2004 - 01:45 pm: |
Leafs bev's been screwing around the past couple days rescan an u should be fine |
