Thread: Panasonic DMR-E85HS WIll this do as I want? |
New member Username: Kayak99
Post Number: 6 Registered: Sep-04
| Posted on Friday, September 17, 2004 - 01:28 pm: |
Will the Panasonic DMR-E85HS record in HD? How would you wire this in order to watch one channel while recording another? FYI, my present setup uses HD cable to plasma, with 5.1 component audio. Also use a dvd player. Thanks! |
xvxvxvx Unregistered guest |
| Posted on Friday, September 17, 2004 - 02:10 pm: |
"Will the Panasonic DMR-E85HS record in HD?" No currently only the HD Ti-Vo (as a standalone DVR) will record HD. "How would you wire this in order to watch one channel while recording another? " Several options, all are listed in your Pannys owners manual. Read the manual, it is your friend. xvxvxvx |
Post Number: 7 Registered: Sep-04
| Posted on Sunday, September 19, 2004 - 08:41 pm: |
Thanks! Haven't bought one yet. Still racking my brain. Cable company plans to have a two disk PVR but they do not know when.  |
