Thread: Surround Sound |
Not Lonewolf in Toronto Unregistered guest |
| Posted on Friday, August 27, 2004 - 11:07 am: |
Can you get surround sound with an older Hughes DTV receiver (that has just the left and right audio outs)? I have a JVC surround sound receiver. |
New member Username: Lonewolf
United states
United states
Post Number: 9 Registered: Aug-04
| Posted on Friday, August 27, 2004 - 11:13 am: |
yes, u can if u have a surround sound system! |
| Posted on Friday, August 27, 2004 - 11:18 am: |
Thank you Lonewolf. Yes I have a ss system, but am only set up for ss with dvd player.What connections do I need to make? I want to be able to have the tv on without having the receiver on sometimes. So do I split the outs and send one set to the tv and one to the receiver? Thx. |
United states
United states
Post Number: 10 Registered: Aug-04
| Posted on Friday, August 27, 2004 - 12:43 pm: |
yes i believe that will work the way i have mine is i have everything hooked up to the ss system even my two vcr's. and my dish. i think it will work. just depends on how many items ur system can handle. hope this helps! |
