Home > Message Board > Home Video > Satellite TV > Archive through August 27, 2004 > Nimiq 1 or Nimiq 2???
Author Thread: Nimiq 1 or Nimiq 2???
Username: Hammeryyz
Can someone tell me the difference between Nimiq1 and Nimiq2..Can I get the same programs on Nimiq2? I have loaded the new fix and been through the instructions very carefully, so I know I am doing it correct..Ny Level is 76% and Quality is 90% but still I get a bad or scrambled channel? What's up with that? I currently am pointing to #1
Username: Deaf
Post Number: 19
If you have aimed correctly,those bars should be yellow,through most of the tps.go through the differant tps. check the quality an strength.If not, its not aimed properly. then scan sat 1 and eveything should be fine providing your using the latest fix...hope this helps
Home > Message Board > Home Video > Satellite TV > Archive through August 27, 2004 > Nimiq 1 or Nimiq 2??? [ « Previous ] [ Next » ]
