Thread: How to disable Smartlock on Magnavox Smart Series |
New member Username: Teach26
Post Number: 1 Registered: Aug-04
| Posted on Sunday, August 22, 2004 - 01:14 pm: |
Here is my problem in a nutshell. Bought this TV second hand for great deal. However someone had already entered the Access Code for the Smartlock on my TV. Is there anyway I can disable their access code? It is irritating when watching a R movie I have to move movie to another TV set currently. Any help would be appreciated.
Unregistered guest |
| Posted on Thursday, September 09, 2004 - 10:53 pm: |
same as above |
New member Username: Bmoyer
Surprise,
AZ
United States
Post Number: 2 Registered: Sep-04
| Posted on Sunday, September 19, 2004 - 12:12 am: |
Same problem, I don't know the four digit passcode to enable/disable smartlock---any ideas would be appreciated |
New member Username: Gaka
Post Number: 1 Registered: Sep-04
| Posted on Tuesday, September 28, 2004 - 08:48 pm: |
same problem, I can't disable access code |
Post Number: 2 Registered: Aug-04
| Posted on Tuesday, September 28, 2004 - 09:38 pm: |
Try using 0000 as your access code. Believe it or not it worked for mine.
