Thread: Is there a way to make jtag port for dp311 and extract the box keys with jkeys |
New member Username: Altinem
Post Number: 1 Registered: Aug-04
| Posted on Saturday, August 21, 2004 - 07:32 pm: |
i was wondering if there is way to make jtag port for dp311 and run dp311 with magic card.
Silver Member Username: Jmill1948
Chester,
Va
Usa
Post Number: 188 Registered: Apr-04
| Posted on Saturday, August 21, 2004 - 10:59 pm: |
check the magic card forum |
New member Username: No_bser
Post Number: 8 Registered: Aug-04
| Posted on Saturday, August 21, 2004 - 11:02 pm: |
absolutely not! can't be done |
Post Number: 2 Registered: Aug-04
| Posted on Sunday, August 22, 2004 - 08:17 pm: |
i found jtag pin number for sti5517 but i cant see the pins on the board because pins stay under the chip.what i am thinking is if we remove the sti5517 and locate the traces for those pins and connect a jtag.is it possible or not? |
Bronze Member Username: No_bser
Post Number: 11 Registered: Aug-04
| Posted on Monday, August 23, 2004 - 12:21 am: |
if you have to play with, then yes you can do that, but i would hesitate doing it... still not worth it... again, it's all about testing. |
