Thread: HDTV PiP Problem |
New member Username: Tase2
Post Number: 1 Registered: Aug-04
| Posted on Sunday, August 15, 2004 - 01:32 pm: |
motorola dct5100/1005 hdtv digital cable set top box. (Comcast) Panasonic PT-40LC12 TV Pioneer VSX-D711 Receiver. When I had just a digital cable box I was able to use my PiP with no problems. Now the 2nd picture comes in as all fuzz. Its the same fuzz I would get if the TV wasn't set to channel 4. If I make it the main screen and move the channels up & down-it won't even allow channel 4. Before I give all the specific hook ups I was wondering if anybody knows how I can remedy the situation. I want to watch the Golf & the Red Sox this afternoon. Thanks Mark
xvxvxvx Unregistered guest |
| Posted on Tuesday, August 17, 2004 - 11:30 am: |
"Before I give all the specific hook ups I was wondering if anybody knows how I can remedy the situation. " Would you like us to drop by and change the connections as well? How about you post exactly how you have setup your connections then we make a brief suggestion that will help?
Post Number: 2 Registered: Aug-04
| Posted on Tuesday, August 17, 2004 - 04:58 pm: |
Would you like us to drop by and change the connections as well? That's exactly what I want. When you be here? |
| Posted on Monday, August 23, 2004 - 11:06 am: |
Yikes...cranky response. Anyway, Mark, I'm having the same problem, and the only way I could figure out any sort of resolution was to hook-up the normal cable line through a splitter...so you can now only watch normal cable on the PIP screen. I was told that was the only way to use the PIP feature, but if you find another way, I'd love to hear it. |
