Home > Message Board > Home Video > Satellite TV > Archive through August 27, 2004 > Someone please help me !
Author Thread: Someone please help me !
outta luck
I have fianlly found someone to fix my dish net card and Im having signal problems....
I can get a signal up tp 100% but it stays red and it says wrong sat. echostar 110 and 119
I have moved this thing everywhich way !
PLEEEESE can you help me out which way do I go??
answer asap ... Im going nuts
Thanks
lonewolf
say outta luck i believe if u go to the setup menu and enter ur zip code the box itself will tell u elevation and azmith. good luck
Username: Fryguy
Barrington Passage, Nova Scotia
Post Number: 119
Why did you move your dish aim ?
Home > Message Board > Home Video > Satellite TV > Archive through August 27, 2004 > Someone please help me ! [ « Previous ] [ Next » ]
