Thread: DVD-RAM |
New member Username: Treyba
Monroe,
LA
United States
Post Number: 4 Registered: Aug-04
| Posted on Tuesday, August 10, 2004 - 08:57 am: |
I recently purchased a few new DVD Movies. One side of the disk was a Fullscreen version and the other was Widescreen version. Was this DVD recorded in the DVD-RAM format? If so, is it possible to record, for example, one hour of TV show episodes on one side of a DVD-RAM disk and then another hour one the other side and then just watch one side at a time on a DVD-RW or DVD-R playback system? |
xvxvxvx Unregistered guest |
| Posted on Tuesday, August 10, 2004 - 11:55 am: |
"Was this DVD recorded in the DVD-RAM format?" Answer: NO " If so, is it possible to record, for example, one hour of TV show episodes on one side of a DVD-RAM disk and then another hour one the other side and then just watch one side at a time on a DVD-RW or DVD-R playback system?" Answer: Again no, once the DVD has been recorded the space is lost. Blank DVD's are only a buck apiece so buy a few. DVD-RAm's are a bit more expensive but will allow you to record over 100,000 times.
